divisiondevils
Need some help from the integra folks.....swap is a 95 gsr motor into a 95 integra ls....
issue 1....to keep the integra ls power steering pump and ac pump what brackets do i need to use...
issue 2.....wiring the gsr into the ls.....does the ls come pre-wired for vtec or will i need to add the vtec wires to the ecu harness....i know i need vtec solenoid, vtec pressure, vtec ground, and knock, but do i need any others like secondary butterfly, evap?....
any information is greatly appreciated....thanks you for your time
