Please Help!
Discussion in 'Civic and CRX - EF' started by diasomtil, Oct 7, 2006.
  1. diasomtil
    diasomtil New Member
    alright, i think i might have figured out what i need to do.
    so i have a 1990 Civic DX sedan with d15b2 (obd0). To put in a d16y7 (obd2b), i can convert my wiring harness from dpfi to mpfi and use a obd0 to obd1 ecu jumper. i'll use a p06 ecu (obd1) and convert my distributor and alternator wiring to obd2... will this work?
  2. ef8
    ef8 Junior Member
    Your going to need to convert to mpfi.Is the y7 from a 99-00?if not then it will be obd2a.If your going to be running a obd1 ecu with a jumper you will need a obd1 distributor.
  3. diasomtil
    it's from a 99-00 yes. so it absolutely has to be an obd1 dis with an obd1 ecu?
  4. ef8
    ef8 Junior Member
    Just wire from DPFI to MPFI.Then use a obd0 MPFI distributor and a PM6 ecu.You are going to need a obd0 1 wire o2 because the y7 is 4 wire.
