Please Read..
Discussion in 'Wheels / Suspension / Tires / Brakes' started by enemycivic, Mar 17, 2003.
  1. enemycivic
    enemycivic Member
    Does anyone know if the 88-91 honda civic's crossmember the part that goes where the steering rack column goes and the tie rods and all that stuff goes. Do you know if its bolted or welded?< :) The crossmember?
  2. D See 2
    D See 2 Senior Member
    Baltimore, MD
    bolted... two bolts on each side. total of four bolts plus the two tie rod ends or whatever so a total of 6 bolts to remove it.
  3. enemycivic
    enemycivic Member
    Thank you and you have no idea how much better I feel. :D
