Plug Wires
Discussion in 'General Tech and Maintenance' started by BigJ, Feb 16, 2003.
  1. BigJ
    Hey I am looking into buying new plug wires for my car since mine are oem and my car has like 120k on it. What kind would be good without breaking 100 bucks for em? anyone know where you can get good ones over 9.3 mm online and whatnot? thanks for your time.
  2. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    Go to here and get some OEM wires. Honda makes the best wires unless your spinning to 10k rpms or have over 500hp plus they are only like $40 or $50. Nolly, MSD, hotwires, they all do absolutely nothing. Also when you order the wires from there, also get a set of plugs for you car. ONLY put NGK plugs in your car. Hparts.com sells them for under $3 a plug.
  3. BigJ
    yeah...so why don't they make a difference? I have heard and seen dyno sheets with actual hp gains from better spark plugs, wires, added up to almost 6-7 hp gains. Is this bs?
  4. asmallsol
    Yes, unless you are running extreme #'s, MSD, nolly, hotwire shit does ablutely nothing. Honda's electrical systems are one of the best in the industry. Save your money and just get OEM hondas. The one bad site that i linked you, you have to have the part # so either email them or call up a dealer and ask for the price and part # of the wires. Hparts will save you like $20
  5. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    i use bocs 4+ electrode the do not require gaping and work great you get a bit better gas milage outa them
  6. pissedoffsol
    don't get me started on bosch
    Calesta- care to comment? :p
  7. thuy
    thuy Junior Member
    I would stick with stock wires. Even though stock wires don't have as low resistance as let's say MSD. They got better insulation which will keep away noise interference away from the computer system. Most high performance wires are low resistance, but create interference. If your vehicle wasn't computerized, I would say go with high performance wires. As for gaining up to 6 horsepower of plug wires. I don't beleive it.
