plz help me
Discussion in 'General Tech and Maintenance' started by buzz944, Aug 25, 2005.
  1. buzz944
    buzz944 Junior Member
    i have a 92 prelue with H22A on it & an ECU but i dont know what kind is the ECU...i have the check engine light is on & i dont know why????? can you plz help me.. by the way you can say i'm new on honda's so plz help me
  2. scottp11
    scottp11 The Seniorest Member....
    El Paso, TX now, originally from Fresno, CA
    Go to Autozone, Checker, etc... they'll check it and tell you what it's for for free.
  3. tab
    tab Super Moderator
    Aberdeen, Washington State
    The ECU itself will have numbers on it. You should have a P13. You could have a P14, P28,P72.
    The code will look like P13-XXXX-A51 or something like that.
  4. reikoshea
    Dallas, TX
    well if you are anything like the rest of the H22 swappers, the code is a knock sensor...if you figure out how to fix it, let us know.
  5. evoracer03
    evoracer03 Senior Member
    what problem is that? i havent run into this yet....
    oh yeah, and autozone and the rest of the parts houses can only check obd2 (96 - up)
    anyway buzz, pull the pass. kick panel and grab the 2 prong plug you see taped to the harness there. put a jumper wire into it and turn the key on. now count the flashes of the cel and identify your problem! the codes will be listed in the emissions and driveability section in your service manual.
  6. reikoshea
    Dallas, TX
    http://www.hondaswap.com/forums/index.php?showtopic=58011
