pm9-a01 ecu ????
Discussion in 'ECU's, Electronics, and Tuning' started by RwD_crx_06, Mar 21, 2008.
  1. RwD_crx_06
    RwD_crx_06 New Member
    miami,fl
    :confused:will the 37820-Pm9-a01 ecu work on the 96 d15b vetc with 4 speed manual trasnmission ? or do i have to put the p28 ecu with the chippin or without chippin on 96 d15b vtec ? please help! thanks
  2. Jeef
    Jeef NO MA'AM Moderator VIP
    You finally post in the right spot.
  3. RwD_crx_06
    miami,fl
  4. RwD_crx_06
    miami,fl
    ????? anyone know about this????????
  5. BrutalB83
    Rochester Hills, MI
    Uhhh...as far as I know there was no D15 VTEC in 96...and I hope you're going for gas mileage rather than performance, because you're never gonna be fast with that turd of a transmission...
  6. RwD_crx_06
    miami,fl
    yeh me either, one of the guy who sold the motor he said he got d15b vtec.. which mean the motor got vtec on the head with d15b block i guess so. but i am not gunna use that motor for race. just for chill on the street but i want to know if p28 ecu will work on d15b vtec engine ?
  7. BrutalB83
    Rochester Hills, MI
    Yes, the P28 will work assuming the motor's OBD1. If it really is a true D15B VTEC it came from a 92-95 rather than a 96. If it's some kind of Mini-Me using a 1.5 block but a newer head, then you're going to need an ECU compatible with whatever OBD system you're using.
  8. RwD_crx_06
    miami,fl
    i think its 92-05 d15b vtec am not sure.. because the guy who sold the motor to me he said he dont know as much about the d series things anyways i guess i will put a virgin p28 ecu on d15b vtec. thanks for your time!
  9. BrutalB83
    Rochester Hills, MI
    Yep, no problem. The P28 should work just fine for you.
  10. RwD_crx_06
    miami,fl
    sure i will put the p28 ecu in the car. hopefully its will running pretty good.
  11. LS_VTEC
    LS_VTEC you get the BRAKE
    NJ
    In order to run a p28 in your 1996 civic, you have to understand a few things...
    1) your car is obd2a
    2) a p28 is for obd1
    3) you will have to buy a jumper harness (obd2a - obd1)
    4) you must use an obd1 distributor
    5) you have to use the proper p28. If your manual transaxle, than you will need a 5speed p28. If your automatic, you will need a p28 from an automatic.
  12. RwD_crx_06
    miami,fl
    Yeh I know, but I got a 96 d15b vtec engine swap into 91 civic crx. That's what I am asking for.
  13. BrutalB83
    Rochester Hills, MI
    Has the car been converted to OBD1? A 91 uses OBD0 I believe...
  14. RwD_crx_06
    miami,fl
    correct, a 91 uses obd01 but i can get the 92-95 harness wiring comes with the ecu plug.^_^
  15. BrutalB83
    Rochester Hills, MI
    That's what you would need...either that, or have someplace like Rywire (Rywire - Online Store) make you a conversion harness.
  16. RwD_crx_06
    miami,fl
    maybe i dont need the rywire make me a conversion harness cause ill get he 92-95 harness wiring comes with the ecu plug. if there need to rywire make me a conersion harness. i gotta to see what i am gunna to do with the harness wiring.:huh:
  17. BrutalB83
    Rochester Hills, MI
    Well yeah, if you're getting the entire harness with the ECU then probably no need to have Rywire do a harness for you.
  18. RwD_crx_06
    miami,fl
