Oh...sorry bout that.
Anyways...
All OEM Honda pistons have to be pressed on...If you decide to go with GSR or ITR pistons, you'll have to shave about a millimeter off either side of the top of the rod (where the wristpin goes), because the opening inside of the GSR/ITR pistons are narrower than the B16/LS.
And the B16 (or PR3, rather) pistons with a B16 head will give you around a 11.1:1 compression, GSR pistons with a B16 head will give you 9.8:1, USDM ITR pistons with a B16 head will get you 10.6:1, and JDM ITR will give you 11.1:1.
Even if you're going turbo, I'd still go with the B16 pistons. You've already got them, I believe, so that's no more money out of your pocket. As long as you have someone who knows what they're doing and won't tune the car too lean so that the pistons melt after 500 miles of driving (cough cough) you'll be fine boosting on 11.1:1. A good friend of mine JUST finished his ITR/turbo a few days ago, standard DRAG bolt-on kit @10psi, the only changes to the motor being a set of GSR cams, put down 279whp/195tq on a VERY conservative tune with Hondata.
High compression + boost is where it's at. It's all in the tuning.
Anyways...
