po6 to p28 ecu problems
Discussion in 'HYBRID -> EG-EK / DC' started by lans, Aug 6, 2007.
  1. lans
    lans New Member
    i have an ls/vtec motor in my eg its a dx i put a 95 ex ecu p28 and the check engine light wont go away i tried to find the code but the wire on top of the ecu that you connect to check for codes wont work what do i do
  2. boostin4fun
    boostin4fun Boosted ls/vtec ohh yeah!
    Omaha
    There is a connector by the ecu that you jump to check for codes not a single wire. Did you add the wires for vtec? If you didnt that is probably why the check engine light is on.
