poorman type r
Tyler
What parts will i need to use to put my b16 head on a gsr block?
you'll need a B16 head and a GSR block... Get some ITR cams and some ARP head bolts while you're at it...
[post=383371]Quoted post[/post]​
I have the head and block and actually have jdm type r cams already, I just need to know if it just all bolts up or if i need to start buying parts, thanks.
and you'll want the ctr/itr pistons, you'll have a lower c/r if you use gsr pistons with the b16 head.
Originally posted by Tyler+Aug 29 2004, 06:12 PM-->
revolution8k
[post=383376]Quoted post[/post]​
it'll bolt right on.
:withstupid: on this one. It will bolt right up. Get a p73 ecu, as the gsr ecu has separate fuel and timing maps for the secondary butterflies.
