eleventy billion sanding drums. Actually, a dremel won't get down far enough. And a die grinder with bigger drums will save you countless hours of work.
You can't "polish" with drums.. and the aluminum will clog up the grinding wheel. If you can get the flapper wheels, Those work best. Don't remove too much material though.. You really need to read up and know what you are doing. Also know that unless you have a very modified motor, you'll only net like 5hp from a standard port/polish on a honda.
thats still 5hp more than i had and i have polished things before my uncle had a machine shop i just always polished large things compared to the heads
