Positive and Negative Effects
Discussion in 'Wheels / Suspension / Tires / Brakes' started by B16RacerN2NR, May 23, 2009.
  1. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    I see a lot of threads of people asking things like, "How low should I go?" "Are wider tires always better?" "What wheel offset should I run?" "How much camber is too much?" ECT...
    Well, I came across this quick little guide, in my book for my suspension class, that I think people could reference just for a ball park idea for what you want/need.
    Let me start by saying it's not a perfect world. There are pros and cons to everything so you just have to take the good with the bad...
    Change - Positive Effect - Negative Effect
    Increase Tire Width - Increased Dry Traction - Hydroplaning in wet conditions, Requires wider wheels(in some cases), Reduced fender well clearance
    Increase Wheel Offset - Increased track width, Reduced weight transfer - Aerodynamic drag, Increased wheel bearing load, Reduced tire clearance
    Lower Center of Gravity - Reduced weight transfer, Reduced body roll - Reduced ground clearance, Reduced wheel travel
    Increased Spring Rate - Reduced body roll - Increased bump shock, Harsher ride
    Increase Negative Camber - Increased tire cornering power - Tire wear, Steering/Braking pull, Reduced straight line traction
    Increase Positive Caster - Straight line stability, Improved camber on turns - Harder Steering, Possible shimmy(wheel shake)
    Lower Roll Center - Less camber change on roll - Increased tire scrub(tire changing path/direction) on roll
    Replace Suspension Bushings w/More Solid I.E. Polyurethane - Reduced alignment deflection(roll steer), Faster anti-roll bar response - Increased vibration, Harsher ride, Replacement bushings usually require lubrication
    1 person likes this.
  2. eg6sir
    good info.. stickied
  3. B16RacerN2NR
    Moving back West...
  4. cjvictoria
    cjvictoria New Member
    N. Chuck, SC
    me likes this new knowledge that hath been bestowed upon me
  5. dc4dude
    dc4dude Member
    chicago, il
    you're not kidding about the lube.... dammed poly bushing and their sqeaks!!!!!!
