Possible fueling problem
APEXi
hey, rite i've still got the same problem as before, my cars having trouble starting and hesitates when i put my foot to the floor, all these things happen totally randomly. i have now found away to start my car up first time... i have to turn the key once to prime the fule pump then turn it back like im turning the car off, then turn it again to prime the fuel pump again, then start it with abit of gas and it starts up. also when i put my foot to the floor the revs just die out like the motor isn't gettin any fuel. this would lead me to beleve it woz a fueling problem?
i've changed the distributor cap and the plugs and leads look fine. is it possible my fuel pump is not able to keep up with the b18 any more and is on its way out? im using the stock d15 fuel pump with the b18 motor.
any help would be a great help, thanks
car info: eg hatch, gsr motor, intake and exhaust, remapped p30
the stock pump should be fine... volume wise at least.
but, it couldn't hurt to throw in a walbro 255 or even the walbro 190 if you're staying all motor or low boost.
i point my finger to the "remapped" p30.
is your ecu socketed?
do you have a chip burner?
if so i can get you a map for your motor that you can burn...
