possible fun d-series
Discussion in 'Engine Building' started by asmallsol, May 16, 2005.
  1. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    I found this hatch, and it has a d16a6 block, a6 rods, zc pistons, d16y8 head milled .030. His estiments on compresssion are around 12.5:1. On the one compression calculator I found, it put it at around 13:1. He is also including a set of CBR ITBs that he had on his older d-series, which I will have to instal. No big deal.
    He is running a stock cam, so it defenitly needs a better cam, but checking on prices, most are only 200. for you d-series fans, with this setup, around what hp could I expect from this, fully tuned of course. Could I expect over 150whp?
  2. jimboburgess
    jimboburgess Go fast, Go Cheap
    nyc
    I would be willing to bet that it wouldn't take much to put down 150whp. Prolly around 130+ hard to tell.
  3. phunky.buddha
    Dallas / Fort Worth, TX
    Wow. Go get the Crower Stage 3, install it correctly (I think you need to machine the followers or towers or something), then go tune and make your 165-175whp. That's the exact same kind of setup I was going to run in the CRX- I had all the parts except the head.
  4. Drake
    Drake Well-Known Member VIP
    Milling the head that much mad the compression rise that much? I dont know much about head work and that sorta thing but what I read about the CR of ZC pistions is that its around 9.5:1 Sounds like it would be a fun motor to drive though. ITB's are the hotness.
  5. phunky.buddha
    In the ZC, yes they make about that much compression. Under a Y8 head they bump up the compression QUITE a bit more.
  6. Drake
    Thanks for the info Calesta.
  7. CiViC_SOHC
    CiViC_SOHC Senior Member
    Well I have a 1992 Civic Sedan that im starting to work on...It has a 98 D16Y7 motor in it (civic DX) and I have a D16Z6 head that is port polished that im going to put on so im hoping I can make that fast lol
  8. phunky.buddha
    Thread jack...
  9. chops95ex
    chops95ex Junior Member
    i'll probally get laughed at for this, but what the hell are "ITBs" :huh:
    this isnt the first time ive seen this. {please excuse this rookie}
  10. NoJokE
    NoJokE Senior Member
    Individual Throttle Bodies.
  11. phunky.buddha
    ITBs = Individual Throttle Bodies
  12. asmallsol
    well this guy hasn't responded to any PMs, so now I doubt its going to happen :(
  13. chops95ex
    thanks.
    learn something every day
    not to take over this thread, but what are the benifits to these?
    if i read correctlym they are off a CBR bike correct?
  14. phunky.buddha
    Not necessarily off a CBR- the CBR has them, and people just use them to make ITB setups instead of paying $1000+ to buy one.
    The advantage is control. You have one throttle per cylinder instead of a TB in front of a big plenum that you have to breathe through. You get more even air distribution between cylinder and faster response.
  15. chops95ex
    appreciate the info. im still learning. {old school hopper gone import}
    B)
  16. asmallsol
    The reason why many use the CBR's ITB's vs other bike manufactors ITBs is that since it is honda, there sensors on their bikes are very similar to their cars, so wiring is not as hard.
    Here is a good pic of some TODA ITBs ($2000+)
  17. chops95ex
    its damn good lookung setup! can you boost on top of these?
    looks like it would be kinda complicated to plumb, if possible
  18. projectxspeed
    projectxspeed Senior Member
    New Hampshire
    It is very possible, the ITB require more tuning, but the plumbing for the turbo is the same
  19. phunky.buddha
    Yup- just build an airtight plenum around them that will hold boost pressure. Lots of people also build a large plenum around the ITB inlets so they can run a filter in front of them.
  20. chops95ex
    Thanks guys, not everybody would take the time to explain. i think we officially took over this thread. shit happens
    :peace:
