possible handling balance problem
Discussion in 'Wheels / Suspension / Tires / Brakes' started by rico2001, Nov 3, 2002.
  1. rico2001
    rico2001 Member
    ok here is the deal. wehn i turn left or right at a moderate or high speed my front wheel on the side of the turn seems to loose traction or sometiems completely lift off the ground. anyone know why.
    kyb agx struts (front & rear) equally adjusted f:4, r:8
    hp racing coilover springs (spring rate f:500 lbs., r:400 lbs.)
    upper strut bars (front & rear)
    front & rear sway bars (f:26mm, r:19mm)
    stock honda accord ex wheels w/195/60/15 tires
    thats all i can tell yea about my suspension.
  2. sportlinecrx
    sportlinecrx Banned
    sounds to me like a worn out/bad shock.
  3. phunky.buddha
    Dallas / Fort Worth, TX
    :werd:
  4. sportlinecrx
    sportlinecrx Banned
    im actually right for once?! lol
  5. rico2001
    rico2001 Member
    i think you may be. i think the rears are going.
