YouTube - H22 Shuttering Missing possible knock sensor
I've fixed the idle surging by turning the TPS up, i also fixed the starting issue by blocking off the EGR valve... or so i thought.
In the other video i have on youtube you can hear it at the end when i push on the throttle a little... it seems to pop and miss just like in the one above.
from the sight on the timing hole my mark on the fly wheel is about 2 inches off... but its all the way advanced... could i have disturbed my knock sensor while working on the car? causing my ECU to go into limp mode making my timing retarded and richening the fuel air mixture?
