Leak? Bad valve stem? Bad pump?
is this a joke?Greetings.
I can't seem to air up my rear driver's side tire. I've tried a few different nozzles and they all do the same thing. I put the nozzle on the valve stem and it won't make a seal, air just shoots out of the tire no matter which way I push the nozzle. The tire literally won't take more than 30psi.. Anyone know what the problem might be?
edit:
The reason why I'm asking is so I can walk into the tire shop with an idea of what the problem is instead of giving them this description.
