possible swap for EH9
Discussion in 'Civic and del Sol - EG and EK' started by asrolsani, Feb 7, 2007.
  1. asrolsani
    asrolsani New Member
    hello,
    I have '93 EH9 running on stock D16Z6...
    i would like to know what are the possible swap? and which is good?
    any modification required?
    i like to have the same 1.6L motor
  2. turbo sol
    turbo sol I need some ligaments!!!
    laurel, montucky (ten minutes out of billings)
    well there are the d16y8 and the d16y7, or you can go for a b-series. i personally love the d series. my d16z6 is pushing out 400hp and 370tq. it took about 6,000 to get there. good running car with no problems whatsoever.
  3. asrolsani
    i did dyno tune for afc neo yesterday and recorded max 96hp on my stock z6. on paper it's 125hp. but you can go up to 400hp... that's a lot.
  4. turbo sol
    takes a bit to get there but it can be done.
  5. Matts96HB
    Matts96HB . Moderator VIP
    I'd say stay D in this situation... build your D
  6. turbo sol
    yep...build the d. if you need advice go ahead and email or PM me.
  7. killercannible
    killercannible Senior Member
    B series def. You guys and your d's. There is a reason SIR's came with b16's instead of turbo d16s.
  8. turbo sol
    yeah it was easier to drop in an n/a motor rather than change the platform around to fit hte turbo...they can push out cars faster if they don't have to mess with putting the turbo together. that and they didn't want to have to change the ecu interface...
