possible swap
Discussion in 'HYBRID -> ED-EF / DA' started by minitrucka, Jun 1, 2005.
  1. minitrucka
    minitrucka Junior Member
    ok i asked a question before about a sohc v but my next question is that will a LS motor pretty much drop into my EF hatch? which one would be less hassle the 90-93 ones or the 95 and up ones?
  2. Drake
    Drake Well-Known Member VIP
    Pick a motor that is the same OBD as your EF. So a 90 or 91. I am pretty sure that 92+ came as OBD1 or 2.
  3. jlicrx
    jlicrx Senior Member
    Colorado Springs
    the LS is not a drop-in swap - you will need mount kit, shift linkage and axles - if your hatch is STD model, you will also need to swap knuckles/hubs
