possibly lost compression?
Discussion in 'HYBRID -> BA-BB /CA-CD' started by bannacrx, Jun 18, 2007.
  1. bannacrx
    bannacrx New Member
    k so my freind has an h22a1 in an accord. he supposidly lsot compression in his f22 before he did the swap. his car would barely start or run. sounded like practially all the cylinders were misfiring and it would barely stay running.
    well hes pretty much having the same problem now with the h22. the same process occured and it happened slowly little by little over a few days got worse and worse. if its to any reference hes using the f22 wiring harness. already replaced the distributor cap and rotor. help.
