Power Sreering Or No Power Steering
Discussion in 'General Tech and Maintenance' started by iceman, Jan 27, 2003.
  1. iceman
    iceman Junior Member
    I' m wondering what would happen if i take the power steering pump off my 93 integra, would i be able to plug up the steering rack, where the hoses go to the rack, and second would this affect steering in anyway ? need some help on this , and would it be more responsive. :blink:
  2. ScandalousImage
    ScandalousImage Junior Member
    when i put my gsr in my civic, I unhooked the power steering belt and drained the fluid, it was good for a 5hp increase. It's not so bad with out power steering, I get by just fine.
  3. chris
    chris Senior Member
    nihon
    u can loop the hoses up and run the fluid thru another cylinder ( i used an extra slave cylinder). or u can simply just take the belt off, its the drag on the crank that is costing u some extra HP. it is a good idea to keep the rack lubed. will help prevent it from breaking down and/or overheating.
    it will make steering under higher speeds a lil less "twitchy" but that is just my personal opinion of a manual versus a power rack
  4. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    If you asre realy serious about removing your PS, look into a steering rack from a 93 Integra RS. They didn't come with PS (it's a manual rack) and it is a direct swap.
  5. iceman
    Thank's guy's i think i'll just diconnect the power steering belt and leave it like that , until i rebuild the motor. thanks for all your responses :worthy:
