Power Steering Tight
Discussion in 'General Tech and Maintenance' started by Jazzy19, May 16, 2003.
  1. Jazzy19
    Jazzy19 Senior Member
    i have a 93 SI and when the car is cold (in the morning). The steering is really really tight.... When the car is warmed up a bit.. the steering gives a little bit more movement. I have already changed the rack and there was no change in the steering... What else could cause this problem... could something be missing or could a line be crimped up somewhere... There is no leaks, the pump and belt work fine... NE help would be nice!!!!!
  2. hanzuki
    hanzuki Junior Member
    You could have a crimped or blocked line. The other possibility could be (and im not a hundred % familiar with the setup on that car) that the u-joints int the shaft could be seized.
  3. Jazzy19
    Everything is still stock...
  4. rsaeini
    rsaeini Senior Member
    Los Angeles, CA
    are you sure the belt is working fine?
    it may be a slipping belt. check the tension on it. make sure the pump is mounted correctly and tightly.
