Where is located the power window relay in a civic 2001 EX?
I am having trouble with side passenger and both rear power windows, they are not working, and their fuses get burned when I replaced them. Only driver side power window is working currently
However, if I removed the Power Window Relay fuse at the fuse panel, the respective power window fuse don´t get burned, I suspect the Power Window Relay is the reason.
