Power windows/doors
Discussion in 'ECU's, Electronics, and Tuning' started by JFR32988, Jun 11, 2007.
  1. JFR32988
    JFR32988 New Member
    well i wanna do power doors and windows in a dx hatch....i kno i have to get the regulators and switches for both but what electrical thing will i have to wire or do???i know the parts its just like i said electrical and wiring things up that im stuck on...any help greatly appreciated
  2. chefboiali
    chefboiali New Member
    I did that swap on my 92 Si. I was lucky, because I knew a guy at pick-a-part, and he let me know when they were putting one up. I got everything really cheap. Well, I got the factory harnesses from both doors, including the under dash wiring that goes from the fuse box to the passenger side door. There are two fuses and a relay that you'll need as well. I'm not sure if my fuse box is different than yours, yours being a non-ex/si, but it's pretty plug and play. It's a really clean swap when you have all of the right pieces.
    Make sure that when you test out the passenger side, that you un-click the button on the driver side that prevents the other window to roll down. It took me an hour of trouble shooting to figure it out :rolleyes:
    Best of luck with it.
