Powersteering on a b18a swaped 90 civic si
Discussion in 'HYBRID -> ED-EF / DA' started by rubenfrmdaville, Apr 16, 2010.
  1. rubenfrmdaville
    rubenfrmdaville New Member
    Watsonville California
    Im trying to get power steering into my hatch, i read in a diff fourm it couldnt be done. I wanna know if this is tru i dnt like how it drives now without power steering thanks ahead of time!
  2. blk91b18
    blk91b18 New Member
    midwest ryda
    i dont see why you couldnt use power steering on it. if you have the pump, bracket and the lines for your car (provided it came with powersteering), it should be doable. you might have to get a different radiator.
  3. rubenfrmdaville
    It alrady has an aftermarket radiator i was just wondering if there would be enough space .
  4. blk91b18
    blk91b18 New Member
    midwest ryda
    should be enough space if theres nothing else sitting in front of the motor. does it have a/c?
  5. rubenfrmdaville
    Nope no a/c i havent realy messed with it too much i got it and it came with the swap so the only thing that bugs me is the missing powersteeping also i was wondering . Removing a/c and powersteeping help make the car faster? ?
  6. blk91b18
    blk91b18 New Member
    midwest ryda
    removing ac and powersteering will help the motor rev up faster as there is less rotational drag on the motor. it wont make it alot faster, but it does help. probably increase gas mileage by a maximum of 1-3 mpg. dont quote me on that. personally i'd leave it out. if the car came with powersteering you probably want to switch out the steering rack for a non powersteering one. or put fresh fluid in the rack and cap off the line connectors on it. that way it wont give out down the road.
  7. rubenfrmdaville
    the car never had powersteering or ac or atleast not after the engine swap. would stock ls brackets work to instal the powersteering
  8. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Only 88-91 Civics that came with PS were the sedans. You'd need to swap crossmember/rack/lines from them.
  9. rubenfrmdaville
    so would i use the stock civic parts or integra parts?
  10. blk91b18
    blk91b18 New Member
    midwest ryda
    use stock civic parts for the rack, lines, and crossmember. use the integra brackets and pump
  11. K2e2vin
    Raleigh, NC
    :werd:
    Those Civics didn't come with B18s.
  12. GlassHeadlights
    Calgary, AB
    My 1990 Si hatch came with PS, but we have them odd ball vehicles up here in Cananadia.
  13. blk91b18
    blk91b18 New Member
    midwest ryda
    :lol:
    blame canada!!! lol jk eh..
  14. GlassHeadlights
    Calgary, AB
    Thats the second time I've got that.:mad:
  15. K2e2vin
    Raleigh, NC
    I've hard of hatches with PS here too, but I believe those were options.
  16. blk91b18
    blk91b18 New Member
    midwest ryda
    sorry didnt mean to offend...
  17. rubenfrmdaville
    thanks man i am new too hondas and building cars all together so how hard would it be to istall it?
  18. EFDX
    EFDX New Member
    you're probably lookig at a weekends work to get it in and working right. sounds to me like a lot of work for very little gain, go pump some iron if you're having trouble in the parking lots, once you are moving you dont need power steering at all. big fat wheels don't help either plus you get less road feel with p/s
  19. rubenfrmdaville
    thats tru its also tthat im not used to it but it would help to sell it in the future..
  20. blk91b18
    blk91b18 New Member
    midwest ryda
    on a scale of 1-5 id say 2.5-3 if you have mechanical skills. little to no experience would be a 4-5. you could have it in probably in about six hours provided you dont run into unexpected problems like breaking stuff. wouldnt try it unless your prepared and have EVERYTHING for the install.
