PR3 into B18b
Discussion in 'Engine Building' started by wanderinman, Jun 6, 2005.
  1. wanderinman
    wanderinman Senior Member
    Raleigh, NC
    Just got hold of a set of PR3 pistons I want to put into my LS motor. I did some searching and can't find a very general answer. Is pulling the motor required to swap the pistons, and is this something where I can change JUST the pistons?
  2. formby
    formby learning in progress
    you can leave the block in the car....remove the head and pan.....
  3. brian11to1
    brian11to1 Senior Member
    depending on milage of the engine you may want a light honing... just remove the engine...
  4. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    bearings, possibly upgrade rod bolts depending on your app.
  5. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    You can do it in the car, but why? Limited space, mobility, and if you find that you need something else done, like aforementioned honing, you have to pull it anyway.
  6. gocivicls
    gocivicls Senior Member
    forest city, NC
    Yea, what he said.
