Pr3 Question
Discussion in 'ECU's, Electronics, and Tuning' started by OldSchoolSwap, Feb 2, 2003.
  1. OldSchoolSwap
    OldSchoolSwap Senior Member
    I was going about 120 in 4th gear and before it hit the 8000 rpm mark (at about 6 or 7k) it "bogged" down and woudn't let me go any faster.
    So i slowed down thinking i might have damaged the engine but all was fine. I did not have a chace to bring it up to that speed again so i'm turning for information here.
    Help!
  2. D See 2
    D See 2 Senior Member
    Baltimore, MD
    sounds like a speed limiter... tell you something you didnt know huh?
  3. AllMotorMonster
    AllMotorMonster Senior Member
    Inland Empire foo!
    Speed governor. All PR3 ecu's have them.
    If you chip it, the speed governor can be removed.
  4. cxjon
    cxjon Senior Member
    man+k+toe
    i think you can hondata that bitch and it will get rid of the rev limiter and would be better then a chip.
  5. sohc em
    sohc em Member
    Charlotte, NC
    get a fields controller and you can bump it up to 135, but you are going to kill yourself or someone else going that fast so don't do it, and yes i am your father.
  6. OldSchoolSwap
    Ah damn! I was afraid you'd say that. The last ecu i had was a P28 chipped, i figured they had taken the limiter out.
    But now that i have a diffrent set up and using this new stock PR3 i guess i found out the hard way ;)
    Thanks for your fast answers guys!
