i just installed full gsr brakes on my 93 vx i bleed all the corners twice. when i press teh pedal it goes almost all the way to the floor. i have not upgraded the mc yet could that be my problem??
Since you now have bigger pistons in your calipers, it takes more fluid to move that piston the same distance. Since you still have your OEM 7/8 MC, your going to have to push the pedal down further to move the pistons to brake. Buy a 91 civic EX MC and you will then have a 15/16 MC which is the same size as the integra MC but it bolts up to a civic booster.
