Prelude Problems
Discussion in 'HYBRID -> BA-BB /CA-CD' started by 96prelude, Jan 30, 2003.
  1. 96prelude
    96prelude Senior Member
    Searcy Ar
    my 96 prelude died last sunday in my driveway. for some reason it just quit pumping gas to the engine. at first i thought feul pump but i have never heard of one just dying like that i mean i had driven the car 2 hours earlier. i think we are going to make sure the fuel pump is getting elctricity but after that i don't know were to look for the prob. any help would be greatly apreciated. :(
  2. SGADDIE
    SGADDIE Junior Member
    Lake Havasu City, AZ
    Must not be any technicians in here. Yes, fuel pumps do quit like that. There should be a schrader valve like that on a tire, but bigger, somwhere on the fuel rail (line to all the injectors) Turn the key on and off several times, then push that little valve, It should squirt fuel out (watch your face) If not, it's either the pump, or the relay. Have fun!
  3. 96prelude
    Searcy Ar
    where is the relay and what do i do to fix it?
  4. SGADDIE
    You will have to check your service manual, but it should be in the fuse/relay box under the hood. Check for fuel pressure first, though, as it still could be something else. Always diagnose the problem first. Engine require 3 things to run, spark, fuel, and compression(air). You obviously didn't lose compression overnight, so that leaves the other two.
  5. [spoon]
    [spoon] Member
    dammit i have a similar problem.
    its not a consistant thing it just does it occasionally. (doesnt matter when or where thou its usually on a slope) usually it starts fine but several time now it just doesnt turn over and keep running. it tries to start and does fire but then stalls out. pressing the gas does nothing to help either :(
    the last time this happened i had 20km on a FULL tank o fuel.
  6. 96prelude
    Searcy Ar
    i checked for fuel pressurre and checked both fuse boxes. no fuel presure and no blown fuse.
  7. SGADDIE
    Good chance that the pump has died. Time to drop the tank. I hope it's not full. It wouldn't be a blown fuse in that box, though. There should be a bank of relays in there, which should be identified in the lid, or in your service manual, and one of them should say "fuel pump relay" It's more likely that the pump itself failed (murphy's law) and you probably just filled her up!
  8. SGADDIE
    That could be the pumps way of telling you it on it's way out, but your's is more likely an eletrical issue(intermittent). Next time it does it, check fuel pressure as I mentioned above, to eliminate the fuel system as an issue.
    BTW, opening the throttle on a computer controlled vehicle while cranking is a no-no, and does no good. It can screw up how the ECU(Brain) reads the signal from the TPS(throttle position sensor) and cause the car to not start at all.
  9. 96prelude
    Searcy Ar
    something is causing my battery to run down while it is sitting in the driveway. we went out to check to see if there was spark to the plugs and it was completely dead. goes to figure though cars hate me. well we got the battery juced up and saw that there was no spark.
    just as a side note i paid to get the security sys taken off the car becauseit kept going off for no reason and it went off while we were trying ot check the spark. teh punk at circutcity will die a painfull death.
  10. 96prelude
    Searcy Ar
    oh yeah the fuel pump is easily accesible from under the trunk board. just for reference.
  11. SGADDIE
    Gotta love how thw Jap's build cars!
  12. kaoskustoms
    kaoskustoms Senior Member
    casper wyoming man
    B)
    alright here it is if you do not have spark the fuel pump will not turn on this is hondas little way to keep the car from fluding so check your ignition system what usuallys happens is that the acg fuse blows this will disable the ignition
    this fuse is located next to an extra fuse so some times people pull it when they blow a fuse if this is not the case chaeck all the fuses if they are ok the problem is 95% the ignitor is bad and honda is known for this problem they will just poop out and some times they will take out the coil as well so see if you can get a distributor from a friend to try and if that is it you know what you need to buy so good luck and remember that the fuel pump only works when the ignition system works
    if you have any more questoins please e-mail me at
    kaoskustoms@yahoo.com chad
  13. 96prelude
    Searcy Ar
  14. kaoskustoms
    casper wyoming man
    whatfixed it if any thing please let us know
    kaoskustoms :ph34r:
  15. 96prelude
    Searcy Ar
    i got my car back yesterday form the shop. we just didn't have the time to invest to mess with it. the shop said that a wire burt up in the ecu. he said it was the first time he had ever seen that in any car. i for sure would have never geussed that. oh and my alarm sys. was from satan so it was what was draining the battery. we had it removed. piece of junk. don't buy a viper alarm.
  16. Vexamus
    Vexamus Member
    You could have a busted TDC sensor, check it out. That's required for the car to properly time the ignition.
  17. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    That'll usually throw a code, though. I forget what the TDC sensor code is on Hondas....
  18. 96prelude
    Searcy Ar
    what is a tdc sensor. should i still care if my car runs great?
  19. Vexamus
    Vexamus Member
    No, dude, your golden. :)
