the accord tranny will bolt to an h22 block but its not great gearing
big gap between 2nd and 3rd and 3rd and 4th and 5th won't pull as hard... i would stick with a h22 trans unless you blew that shit up and need a cheap replacement...
Any H or F series tranny will bolt up, minus the S2000 of course. Unless you plan to boost, stick with H22. The H23 is a decent second choice. F series is least desireable unless you boost and want longer gears.
