YouKnowWhoIBee
my avatar is better.
To make a long story short, i have a bad piston ring in my #1 cylinder. So instead of replacing the rings and having to take apart the motor, i am just going to replace it with a lower milage motor. I now have 150,000 miles on my car and this motor has 102,000. When Z6CRX and I take out the original motor, what things should i replace when i swap it in? I am already going to replace the front and rear main seals, transmission fluid, motor oil, spark plugs, rotor, cap, wires, re-using my new distributor, re-using my new alternator, and changing the timing belt to a new timing belt. What else should i buy so i will have a smooth runing motor again ? Because now i get 21 mpg and black smoke comes out of my motor when i am at wot, and when i start the motor up, white smoke sometimes pours out like a cloud
