cvcsleeper
Member
If the engine that I'm swapping into my car requires more control units than my car actually has (e.g. evap canister vent shut valve, bypass solenoid valve), can I connect a jumper wire from a power source on the ECU to that control units pin to prevent it from throwing codes? I'd make sure the voltage is the same.
