problem after timing belt replacement
Discussion in 'General Tech and Maintenance' started by g2ooo, Aug 7, 2005.
  1. g2ooo
    g2ooo Junior Member
    i just changed the belt on an accord, now when i try to crank the engine it cranks real slow. and no it's not the battery. the engine is set to tdc but i noticed that the balance shaft pulleys are not lined up where they should be. could that be the problem?
  2. TWISTEDIMAGE
    TWISTEDIMAGE Senior Member
    CASPER WYOMING
    balance shafts might be the problem fix and try again.
    its pretty bad to come on here and ask for help when you know that there is a problem fix the problem first and try try try again.
  3. g2ooo
    g2ooo Junior Member
    i know the key is to try and try and try, but i don't have much time to work on my car and my girl always be tripping bout it, so i tought i would ask and see all the things that could be wrong and then go for it.
