Problem with AntiThief flash
Discussion in 'Accord' started by Vincent, Dec 11, 2008.
  1. Vincent
    Vincent New Member
    I have the Honda Accord 2000 and the ani-thief is flashing all the time. I cannot use my radio. I tried use the code to reset it, but didn't work. It's frozen..the screen shows " CODE 3".
    Anone know how to do or any advice to reset my radio.
  2. 95b16coupe
    95b16coupe New Member
    ct
    thats how many times you have tried to enter the code. if you put in the wrong code, then it wont work. if you are sure you have the right code, it will work just fine.
  3. DESPAIN
    flower mound TX
    Shot in the dark........ Unhook battery for a few min. See what that does...........
  4. 95b16coupe
    ct
    it starts it over and you will have to re-enter the code. thats how it gets re-set in the first place.
  5. DESPAIN
    flower mound TX
    Well sounds like someone needs the right code..............
  6. calmfornow
    calmfornow System Failure Racing
    Zionsville, pa
    to make it easy...call the dealer and get the code for the radio...they will ask for the VIN number and stuff like that....sounds like you have the wrong code like everyone else is saying
  7. calmfornow
    Zionsville, pa
    if no luck....screw it, get a aftermarket headunit....alpine or eclipse is basically the best you can get also...im a mobile installer, and its a pretty straight foward job...shouldnt have a problem with a factory amp or anything so just swap it out
