-94-AccordH22
hello all.
im waiting on my ecu so im still using the f22 sohc non vtec auto ECU. someone said i could use it still but it would throw a code. well this thing is screwed up. i dont know if its the ecu that finally learned its the wrong motor or messed up wiring. (which i dont think because it was running fine before the ecu got settled in.
but the only sensor im pretty sure unplugged is the intake air temp.
the motor will run at like 400 rpm. then when i give it gas it will go to like 4000 than ACT like it has a rev limiter. im afraid to think but i dont know if one of the cylinders or valvetrain on a cylinder is shot.
but what do you guys think from this. i almost am sure its the ecu becuase i already switched a6 and 11 but its still the stock ecu off my f22 so i dont think it recognizes anything?
thanks
thanks
