problem with spark
Discussion in 'ECU's, Electronics, and Tuning' started by typesiracing, May 17, 2004.
  1. typesiracing
    typesiracing Senior Member
    ny
    i just completed a swap recently....started the motor first chance i got because i built it myself and wanted the relief....well it started and sounded great...then for now appearent reason the thing wouldn't start like 4 tries later....i started it one day and tried later the same day after hooking up the rad and some minor non electrical stuff...nothing....well i gutted the distributor and replaced everything...now i get spark but ....its orange
    i tested the compression i'm getting 12:1....with this high compression i know how critical a good spark is....my question is how to make that orange spark a bright blue one so i can be on my way....thanks guys
  2. typesiracing
    ny
    anybody have any ideas? get this...my friend came over and i wanted to crank it to show him the spark and the car started!!!....then when he left i tried to start it again and nothing?!?!?
    1. i checked all the grounds for good contact
    2. i checked distributor for voltage...good
    3. checked all fuses anyway....good
    still nothing
    thanks
  3. brc80
    brc80 Senior Member
    Southern California
  4. typesiracing
    ny
    which relay are you thinking of? i am getting 12volts at the distributor when the motor cranks and i know i'm getting fuel. Everything was fine with the d-series in it...maybe i'll put it back.....NOT
  5. cycloneb18c3
    cycloneb18c3 Senior Member
    New Jersey
    better plug wires perhaps?
