I have a 1898 CRX HF and im putting a OBD I GSR into it. Ordered my swap harness from Rywire and i start plugging everything in but only have one three wire plug to go onto the throttle body. Both the TPS and the MAP sensor are three wire. I am unsure if the plug is just not on the harness and I have to look for it on the chassis. Secondly I have the two plugs on the transmission, Im assuming one is the electronic VSS but the other im unsure of. Its located on the passenger side of the transmission and faces up. After this post I am leaving to head to my shop so if pictures are needed i can take them.
Thank you for your help in advance,
Tom Pappas
Tom Pappas
