Slammed90Lude
Yeah so, the integra still has the same old problems- warm days usually mean it won't start after being run for a while- I know that there is spark, compression and air- I know the problem is somewhere in the fuel system- I dunno what the problem necessarily is and without any CEL's it's hard to pinpoint- So i'm just going to replace every part of the fuel system that could cause this problem- I know this sounds like overkill, but the car has 220k on it, and is still running on the orgininal everything-
I figure i need to place the fuel injection relay, fuel pump, filter, fuel pressure regulator
is there anything else i'm missing? or someplace i should start first
