ThatGuy4life
The Riced Sleeper
I'm getting to the point where I'm just bout to take my car in to the dealership and see if they can figure out what's wrong. Keeps throwing random cels first it was throwing all 4 misfires reset the ecu code went away then threw a code for knock sensor that went away after about 30 minutes then the misfire codes came back, replaced ignition wires car rode perfectly for a day then the knock sensor code came back along with a manufacturer ignition malfunction code.
Main problem though is while driving once I hit 5500 rpm in all gears the motor stutters/hesitates it will just stay at 5500 for about 6-8 seconds if I stay on the pedal it'll eventually catch up and take off. Ignition system is good, I thought it might've been the ecu as I was still using the si ecu but put in a chipped skunk2 ecu on Friday and it's doing the same thing. The only choices I'm left with are either the timing or fuel system. Anybody have any ideas?
See setup below:
2000 si with Built B18C5-type R motor
Head is ported & polished
Crower rods
JE pistons
Skunk 2 stage camshafts
Skunk 2 intake manifold
REV Valves Springs & Retainers
Act Flywheel
RPS Six Puck Sprung Hub Clutch
AEM Cam Gears
AEM Fuel Rail
STR Cam Seal
Stock LS headers soon to be JDM type R 4-1 headers
Polished K2 cold air intake
Throttle body spacer
APC Cat-Back Exhaust
NGK Ignition Wires
See setup below:
Crower rods
JE pistons
Act Flywheel
AEM Cam Gears
AEM Fuel Rail
STR Cam Seal
NGK Ignition Wires
