I've been working on this swap and trying to get it timed.
Here are some details about the swap and what I have used:
H22 engine/trans
H23 fuel rail
H23 distributor & coil
H23 harness
H22 ecu
I am not getting the timing mark coming around into view. I even went through the timing window and marked in "white" next to the "red" mark so it would be more visible with the timing light.
I have the timing light plugged into No 1 dist cap and the IAC connector disconnected, with the trans in 'Neutral' and the rpm about 750. Also have the jumper wire in the service connector.
What am I doing wrong?
H22 engine/trans
H23 fuel rail
H23 harness
H22 ecu
