problems with d15b in 98 ek9
Discussion in 'Civic and del Sol - EG and EK' started by ek9Hatch, Dec 26, 2007.
  1. ek9Hatch
    ek9Hatch New Member
    Dirty Jerzy
    i bought a d15b motor and put it in. i am having a problem with how to wire up vtec because my car was non vtec before, so if anyone could help i would greatly appreciate it. also my car starts but when u rev it up it dies out as if it is not getting any fuel. thank you
  2. 97DXcoupe
    97DXcoupe GSR Swapped/Gutted
    lol d15b in a EK.
  3. AHHVTEC
    AHHVTEC Well-Known Member VIP
    Alabama
    d15b came stock in some ek and they were also 3 stage vtec
  4. AHHVTEC
    Alabama
    but what d15b did you get, is it a obd2a motor and is it single vtec or 3 stage
  5. 97DXcoupe
    d15b stock in EK?????????
    why would you bother to swap in a d15b into an ek though?? when you can get a LS for about the same and be way faster with much more performance options and all around better outcome??
    i just see a d15b being a complete waste of money...
    d15b
    single overhead cam
    less then 130 hp
    1.6l
    3 stage vtec
    imported from JDM
    b18b
    146 hp
    double overhead cams
    low compression perfect for turbo
    optional ls/vtec swap
    built strong
    large displacement
    LOTS of availability
    LOTS of performance options
    can get them locally
    more.....
    just dont see the reason why. he wouldnt even have to bother wiring up vtec unless he did the ls/vtec swap later.
    Good luck with your swap though. there are alot of forums out there with write ups about SOHC vtec wire ups.
  6. AHHVTEC
    Alabama
    you look it up im right your wrong, what does it say above my avatar pic
  7. 97DXcoupe
  8. AHHVTEC
    Alabama
    just saying im right,, and it says HONDA GOD.
  9. 97DXcoupe
    did you not read my post?
  10. AHHVTEC
    Alabama
    what about it
  11. 97DXcoupe
    what are you trying to say that im wrong and your right???
    are you saying a d15b is better then a b18b??
    in that case, i, and others for that matter, would probably end up saying your wrong
  12. AHHVTEC
    Alabama
    no,,what im saying is that you told me that there is no d15b vtec for the ek. when there is thats where you was wrong and i was right
  13. 97DXcoupe
    :confused: Where the hell did i say that?
  14. AHHVTEC
    Alabama
    lmao dude i quoted you post # 6
  15. 97DXcoupe
  16. AHHVTEC
    Alabama
    count down to the 6th post, and you will see where i quoted you, before you edited it lol
  17. 97DXcoupe
    first off. i was making a joke out of it, was trying to make the point of putting it in a EG as a replacement is all its good for. second off, i hit enter by accident when i was trying to clear out the post and retype up what was entered in RIGHT as you replied.
    you took it way to serious, i didnt even know it posted cause when i hit enter instead of backspace i got a clear text box. hence why i didnt know it posted
  18. 97DXcoupe
    but what ever, MR HONDA GOD... freak out like you own the forums lol.
  19. AHHVTEC
    Alabama
    just saying you was wrong, so next time befor you start saying that i am double check yourself,.
  20. 97DXcoupe
    where did i say YOU were wrong? please qoute me where i listed your name and right by it said you were wrong?
