problems with my EF hatch
Discussion in 'General Tech and Maintenance' started by minitrucka, May 31, 2005.
  1. minitrucka
    minitrucka Junior Member
    okay im having problems with my hatch im going to try and describe everything as clearly as i can
    first one is that for some reason fuel vapors are coming threw my gas cap i changed it still same problem so i tried to disconnect and plug my evap purge soleniod problem still there so im thinking its my 2 way valve maybe?
    secong problem is that my car hesitates badly when the a/c is on in first gear tried giving it a tuneup nothing changed because it kinda hesitates with the a/c off but not as bad
    last problem is that when i start it sometimes it runs really rough i have to gas it and hold it a little then it eventually clears up
    thanks anyone who helps
