I started something I couldn't finish. I prefer you to contact me over email. evdeneale@bellsouth.net I'm located in Georgia.
All the parts are currently on the car and have less than a 1,000 miles on everything. Everything was purchased new unless stated otherwise. I have recipets for just about everything. Here goes.
JDM D15b Vtec Engine - Purhased from hmotorsonline.com
Milage: 30,000-40,000 I've put less then 1,000 on it. It runs perfect!!!
$900 (local pickup only)
-New timing belt and power steering belt
-New ARP Head studs
-New OEM Headgasket
-New Motor mount inserts
-New Axles (lifetime warranty reciepts)
-Transmission included
-New SPEC clutch, pressure plate and ACT flywheel.
-Shift linkage
Hondata s200 and RC 440 Satarated injectors
$450
Garrett T3 turbocharger
It's perfect condition. Used for a couple test runs and start-ups.
Inlcudes:
-inlet metal gasket
-k&n filter
-transition coupler to intercooler pipes.
$450
Garrett T3 oil lines - from stealthmodeperformance.com
-Oil feed from oil pressure sending port and other nesasareyparts
-Oil Drain line and nessacary parts
$55
BMC Race Turbo Manifold
It can be seen in the first picture.
$150
Tial 38mm Wastegate
Includes turbo vacumm line, 7psi spring and 10psi spring.
$180
Tial BOV (Black)
Already welded to intercooler pipe and includes vacuum line.
$150
Front mount intercooler
$150
Intercooler pipe couplers
Inlcudes 8 couplers with 16 clamps
$25
B&M Shifter - ALL Honda/Acura
$45
Spoon Sports Shift Knob - Black(Duracon)
$55
GSR Wheels with TOYO T1-R tires
Tires have more then 90% tread left. Wheels are in excellant condition.
$500
-New ARP Head studs
-New OEM Headgasket
-Shift linkage
$450
Inlcudes:
-inlet metal gasket
-k&n filter
$450
$55
$150
Tial 38mm Wastegate
$180
Tial BOV (Black)
$150
$150
$25
$45
$55
$500
