Proper way to remove Power Steering?
Discussion in 'General Tech and Maintenance' started by MarkJimenez99, Sep 9, 2003.
  1. MarkJimenez99
    MarkJimenez99 Senior Member
    I would like to remove my power steering completely. It is currently disconnected from the pulley and it's just hanging there. Is there a proper way to remove it entirely? How do I remove the power steering fluid completely? Do I just pour it out? I don't want to make a huge mess. What about the hoses? Any help is greatly appreciated. Thanks.
  2. B16
    B16 Super Moderator VIP
    yay area, CA
  3. La_Pieuvre
    La_Pieuvre Senior Member
    Dallas, TX
    not to hijack the thread or anything, but does removing the PS really do that much of a difference in freeing up power or mainly just in the stiffness of the steering? I was thinking about removing it since it's not like I parallel park on a daily basis and the long straight roads in Dallas don't require much steering. Now I've driven cars with the power steering broken and it was not fun! keep in mind that it was a 3500+ lbs Mercedes but still...
    The links B16 provided are very informative on the process but not on whether or not the whole thing is worth it.
  4. MarkJimenez99
  5. E_SolSi
    i ripped out my PS
    the feel is much better now
    the whole assembly was pretty heavy
    now there is less drag on the engine too
    parking is a little harder now though
    over all i love it
  6. MarkJimenez99
    I wanted my power steering back when it was removed. I got used to it so I didn't care anymore. Since it's disconnected I thought to myself, "Why not just remove the damn thing since I'm not using it?" So here I am. It's actually not that bad unless you're a true pussy. You can feel the turns better. 3 point turns are a bitch though! E_SolSi, you literally just ripped it out?
  7. E_SolSi
    took the pump out
    took the resivoir out
    took the lines out
    looped the steering box
