ps & ac
wlp2008
i have a 88 crx si with a d motor, not sure if im going to swap to b16a or keep it d. but either way the car doesnt have power steering or a/c.. i have everything i would need but its off an f-series motor(accord) would the ps and ac be compatible from f to b/d motor??!
well your problem is twofold, first is that if you want ps, you need a vehicle that came with ps..... or you could swap in a ps rack from one of the four door ef's, but nevertheless, your si never had ps from the factory. second, the f22 ps and ac does not bolt up to either the B or D motors.
