Pulleys...
Discussion in 'General Tech and Maintenance' started by Gen2Teg, Jul 28, 2003.
  1. Gen2Teg
    Gen2Teg Senior Member
    san francisco
    simple question, just wondering, anybody know how much HP a complete pulley kit will put down on a LS? AEM pulley kit with a UR crank pulley, no AC. I've heard a lot of different things from different sites, people, but i'd rather check here to see if anyone actually knows, or a rough estimate.
  2. rsaeini
    rsaeini Senior Member
    Los Angeles, CA
    IMO, don't swap out your pulley. don't swap out any of them, especially the crank pulley unless it has a harmonic balancer.
    it's not worth it.
  3. bectondavis
    bectondavis Member
    I have heard this before. Harmonic Balancer? UR and AEM just lighten the pulleys and maybe make them a bit largerI think???? (I don't Know) How can this cause vibration?
  4. Gen2Teg
    san francisco
    no i've been having them for hella long, and i can feel a huge difference. I would get it all balanced but you know.... laziness and cheapness. Im just wondering now how much im putting down.
  5. bectondavis
    bectondavis Member
    They state about 3 more Horsepower. Not a lot!
  6. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    The majority of the power is going to come from the crank pulley itself, don't bother with the AC,PS pulleys. skip the pulley and keep your stocker.
    Milan
  7. egb20hatch
    egb20hatch Junior Member
  8. pissedoffsol
    a balanced pulley does NOT mean a balanced rotating assembly.
    in all reality, the pulley would have to be balanced whil eits on your crank. honda does it. your local balancer guy won't have a clue.
    stock. end of story.
  9. word
    word Senior Member
    what about the CTR N1 crank pulley?
    lightened crank pulley with no AC or PS?
  10. pissedoffsol
    the n1 pulley is also not balanced.
    even if it is- its balanced on the motor it came from- not yours.
  11. bectondavis
    bectondavis Member
    So to beat this dead horse, does anyone know how to balance the pulley on their vehicle?
    All most people want is good ideas about power. It seems most are against pulleys but the company's make them for a reason. If you take the pulley and balance it properly for your specific motor are they worth the $100 or so? LBS is very important in racing and balance is of course the only way to go.
    Being lazy about balace will cost you in the long run with other problems.
  12. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Your local machine shop should know how to do it. When I assmebled my engine I took the machinist my entire rotating assembly (pistons, rings, rods, crank, bearings, flywheel, timing belt pulley, and crank pulley) and had him balance the entire thing as a unit. The more stuff you add to the balance job, the more expensive it gets. But it can save you money at rebuild time.
  13. Gen2Teg
    san francisco
    ok so back to my question... how much does it put down? and they state more than 3hp.
  14. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    Of course they do. MSD advertises a horsepower increase with their plug wires, and lots of companies offer insane gains from their intakes/headers/etc.
  15. JDMilan
    Boca Raton, FL
    it depends on how much your motor is putting out, to answer your Q i would guess-ta-mate roughly 2whp.
    But keep your stocker in all retrospect.
    Milan
