Pulling A B18
brian11to1
When pulling the engine and transmission where do you bolt the chain so as to not create stress points.. Please supply pictures. I thought about taking off the distributor and bolting one part of the chain on that and then the other to the factory lift point on the driver side of hte engine by the motor mount. But I'm also taking the engine and transmission so theres a little more wieght... what to do... sorry if htis is a stupid question!
Is what my freind Adam did when he swapped his Tiburan motor is he got one of those biig floor jacks and put it under the motor and lifted it up just enough to get the chains (well he used 4 guage power wire cause he didnt have chains) into the motor mounts on the motor. I dunno sounds messed up but it worked. Personally I would just throw a chain around the whole motor. Use two and kind of make it V up into the one in which is hangng from the cherry picker.
