Pulling Codes, Jumping ECU Method
Discussion in 'General Tech and Maintenance' started by khai_tuan_nguyen, Jul 18, 2005.
  1. khai_tuan_nguyen
    khai_tuan_nguyen Senior Member
    I tried jumping the harnesss to pull codes for a 95 HB si with stock harness, p28 ecu with hondata s100. I jumped the wire and the srs light just blinks forever no long blinks, no pauses or anything. It just blinks fast indefinitely. Any ideas what i am doing wrong.
    I jumped the blue connector with only 2 pins that has a black and brown wire. It was not connected to anything.
    thanks in advance
  2. 94CivicSlow
    94CivicSlow Senior Member
    B0ST0N
    Was the car running.. car should NOT be running, put it on the last click before starting.
  3. smooth_criminal
    smooth_criminal Senior Member
    are you trying to check your ECU for codes or the SRS system?
    Becuase they need to be runn seperately. The SRS jumper is under the steering wheel. Looks just like the ECU jumper.
  4. khai_tuan_nguyen
    I am trying to get the check engine codes. I jump the harness on the passenger side by the ecu with the key out. Then I jump the 2 pin plug and put the key in and turn to the click just before starting and then the srs light just blinks not the check engine. There is another blue plugby the ecu that is also loose. It has 3 pins and is black, white with red and one other wire i can not remember.
    What could I be doing wrong.
  5. pissedoffsol
    hondata is gay.
    with hondata, you need to use the data logger to check error codes.
  6. phunky.buddha
    Dallas / Fort Worth, TX
    Huh? I've never had to use the data logger to check codes.
  7. khai_tuan_nguyen
    How do you do it then. The car i am working on just blinks with the srs light rather than the check engine and it just continuously blinks fast, with no pauses or anything. Is there a chace that sensors could be hooked up wrong say check engine and srs?
