pulling out hair!!!
Discussion in 'HYBRID -> ED-EF / DA' started by 1slowb16ef, Aug 8, 2005.
  1. 1slowb16ef
    1slowb16ef Junior Member
    i am rewiring my 89 std from obd0 jdm b16 using pr3 to a obd 0 using jkobd adapter blah blah . the company who install this engine back in 99 did a really hack job blah blah . after finally getting the cel to work after the cut it off i find i have codes 1 4 6 and 15 call will not start after the obd0-1 swap
    please correct me if im wrong here
    code 1- oxy sensor -shouldnt cause car not to start
    code 4 crank position sensor - ?? is this the same as the cyp sensor ? with the
    new obd1 distributer how does this work out ??
    code 6 - coolant temp sensor - shouldnt cause car not to start
    code 15- ignition output signal? what is this and how do i trouble shoot it ?
    i need help im frazzled here
  2. brian11to1
    brian11to1 Senior Member
    why are you using an obd1 dist. if the car is still obd0?
  3. The_B_Sleeper
    The_B_Sleeper Junior Member
    code 15? when my hatch threw me a code 15 it was the air intake temp sensor
  4. 1slowb16ef
    brian ... different cars/ecu codes are different
    the b sleeper.... the car is not obd0 i am in the process of making obd1
  5. The_B_Sleeper
    hahaha missed that part.. sorry bra
  6. brian11to1
    ahh, ok. anywho code 15 means something in the dist. is bad. maybe not wired correctly.
