pulln to right under hard accel.
Discussion in 'Integra' started by 8secHonda, Mar 29, 2010.
  1. 8secHonda
    8secHonda New Member
    ok guys this is the only car that i had do this to me,
    i have a 90 model teggy, if i hammer on it taking off the car seem to pull to the right, its not very bad but it is noticable. has anyone had this prob yet or can tell me what to chk?
    prob 2- my shifter has alot of slack in it when its in gear.. any gear.. could this b the bushing in the arm that goes to tranny ?
    thanks guys..
  2. 94tuner
    94tuner New Member
    warped rotors... is it all the time when your accelerating or is it also when your coasting?
  3. eg'sforlife
    eg'sforlife New Member
    29 stumps, CA
    Welcome to torque steer or you have alignment issues. It realy depends if that is the only time its happening or not. Warped rotors would cause a pull during braking
  4. 8secHonda
    oh ok it only happens under hard accel. during all gears it drives straight w normal driving.coasting it drives straight, warped rotors would cause that ?? i woulda nvr thought that ..
  5. 94tuner
    94tuner New Member
    that was just a guess i didnt know if it was all the time or just during acceleration...
  6. 8secHonda
    oh ok kool, ill chk that tommorow n c if they warped or at least how they look..
  7. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Warped rotors shouldn't cause that. If anything, if they were being engaged it would pull all of the time.
    Common cause for hard pull is worn bushings and possibly tie rods/alignment. Torque steer should not be that significant unless you're putting down a lot of power(and have traction). Since you have a 90 Integra, definitely check the radial arm bushing located under the front radiator(the radial arms keep the control arms in place; if it were worn out it would allow the LCA to move back/forward during hard braking or hard acceleration).
  8. 8secHonda
    oh ok, its just a stock b18a1 w fully adj cam gears ( i think it is stock anyways). its not pulling very bad but it is noticable. ill check all the bushing in the morning. thanks bro
  9. 94tuner
    94tuner New Member
    true...if its not pulling while braking you should start with an alignment and see if that will solve your problem
  10. b18JDMcivic
    b18JDMcivic Junior Member
    Or just torque steer.. If it doesn't pull when your braking then your fine. But if it does then alignment. Warped rotors will just cause it to shake when you are braking, and won't stop as fast. So stop freaking out....
  11. 8secHonda
    lol not freeking out yet , just thought i had a bad suspension issue. i noticed that it was a salvage vehicle (didnt kno till after purchase) and was kinda worried about safety, thanks for the info bro.
  12. kelsodeez
    kelsodeez New Member
    bay area, CA
    LSD will remedy the torque steer.
  13. 8secHonda
    LSD??? :confused:
  14. kelsodeez
    bay area, CA
    Limited Slip Differential
  15. 8secHonda
    oh dam lmao ..... i knew that , dont think i need another beer tonight lol
  16. ricksautomotive
    ricksautomotive honda dealer tech
    lancaster, ca
    warped rotors will only be noticed during braking. the steering wheel will vibrate
  17. 8secHonda
    thats what i thought, it was suprised to hear the other lol ..
  18. ricksautomotive
    lancaster, ca
    the radial arm may be bent slightly at the lower control arm mounting location (or somewhere else). this is caused by hitting a curb or something like it with the front right wheel. measure the wheelbase from the center of the axle nuts (wheel center-to wheel center) on the right and left sides. the right side will probably be shorter than the left by about an inch. thats about how much youll get from the bushing and redial arm getting screwed up. maybe an inch and a half.
  19. 8secHonda
    ok ill check into that, i did notice that the car was a "salvage rebuild", i didnt know that till i bought it, i dunno how i missed that sticker... im kinda iffy about puttin too much in it and racing it. not sure how safe it would be..
  20. ricksautomotive
    lancaster, ca
    if the sub frame is good you can race it. and if its not...race it anyway. you can replace the control arms, radial arm, etc. hell!! if youre up to it you can replace the front sub frame but you better get it square. also check all the bushings like someone else said. when i messed mine up it wasnt too bad. i took a hard left onto a street at like 90 mph. i hit the curb a little but it was pretty damn fun
