Putting A H23a1 Into A 96 Civic
Discussion in 'Engine Building' started by 300hph22civic, Mar 5, 2003.
  1. 300hph22civic
    300hph22civic Member
    Hey guys I was thinking about putting an OBD2 H23A1 into my 96 Civic , why you may ask?? well I figured it was a good start since it is already rated at 160hp, and later if I wanted to put a H22A Head I hear that really unleashes the power, sort of like a LS/VTEC conversion,
    can anyone give me do and donts of this swap, also since it is OBD2 and right off the bat I will not have the H22a head, will wiring or swapping be difficult since the car is an OBD2 as well??
    Thanks for any tips or answers,
  2. 300hph22civic
    Can anyone help please???
  3. 300hph22civic
    H23 into a 96 Civic , help please
  4. judonoh
    judonoh Junior Member
    it's possible to do. Need to have a mount kit, no big deal. But either do the h22 or h23 don't mix. There is a big increase in headaches rather than power as compared with other franks. Or you can just go ahead and buy the JDM h23vtec that came in the type-r accord.
  5. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    I don't think the H23 VTEC came in the Type R Accord, I thought it just came in a couple of years of an Accord wagon over in Japan....
  6. thetoymaker
    thetoymaker Senior Member
    In the mountains (love driving to work)
    Yeah I can help u...............
    FBF
  7. h22turbophilippines
    h22turbophilippines Junior Member
    yup that can be done. h22 and h23 uses the same mounts. i got an h22 in my 96 civic. problems had to deal with for the swap: engine mounts, shift linkage and shifter assembly, drive shafts. but it will fit and kick everyone's ass!
  8. bong123
    bong123 Junior Member
    i suggest you just get the h22a primarily because its already got huge power and especially torque in stock form. if your still not contented.....work the head.... want more???......hi comp pistons
    great n.a. reliability!!!
  9. dohcvtec_accord
    The left lane
    The H22 has the exact same torque numbers as the H23.
  10. mad-racer
    mad-racer Junior Member
    my borther has a h23a1 in his 93 cx it has a h22 ecu and h22 tran on h23 it runs good it's got vtec at five k rpm, not that hard to get it :roll: :roll: in
  11. YouKnowWhoIBee
    YouKnowWhoIBee my avatar is better.
    Maryland
    I didnt think an h23 had vtec. And someone posted about doing a h23/h22 swap but i cant remember who sorry.
  12. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    They had F22B's in the wagon, prelude Si vtecs had H22A's, and the Si's also had the F22B, all I can find is the JDM F23A from the 97-01 Accord wagons, and one model that had the H23A in a Accord wagon. Accord Euro R's had the H22A also.
  13. xj0hnx
    C.C.TX.
    Ok, here it is, 2000 Accord SiR wagon 200PS 2.3L vtec H23A...
    200PS@6800rpms (197hp
    220Nm@5300rpms (162lbs-ft)
    10.6:1 compression
    87mm bore
    95mm stroke
  14. reckedracing
    reckedracing TTIWWOP VIP
    NY
    you're looking at big headaches if you think you can just throw on an H22 head...
    for the power to weight i would advise for a B series non vtec...
    motor will prob run about the same price as an H23, way better weight distribution for the car, and then you can MORE EASILY throw on a vtec head for the extra horses...
    someone on here is doing the H23 with H22 vtec head, search the forums and you should find it, he advises that you just start with H22 block cause of the cost involved with the H23 vtec conversion...
    and i believe an LS motor will be fairly bolt in to a 96 civic...?
    less cost for mounts...
    and i have heard of the H23 vtec from japan accords, also head that one of the F22's came turbo'ed in japan... anyone know the truth in this?
    EDIT: so H23 vtec has the same figures and stats as the 2.2 counterpart...???
    then why????
  15. xj0hnx
    C.C.TX.
    Because Honda engineers drink Bud Dry,
    Why ask why?
  16. Jeef
    Jeef NO MA'AM Moderator VIP
    To whom ever bumped this thread, it has been dead for almost a year, start a new thread.
